Attach a GameObject to a wall on launch?
I'm sure this is possible, but not sure where to begin with it.
Basically, when my app launches, I would like to attach something (e.g. a poster, or a data readout, or whatever) to the nearest wall.
Optionssubere23 ✭✭
I would recommend going through the 230 Spatial Mapping Tutorial for help there. Assuming you are using Unity, you will need to allow the app to spatial map, or load a previously mapped space. At this point the tutorial will use SurfaceMeshtoPlanes to map out walls and floors. You can after these processed are done, place objects where you want. Look at the spacecollection prefab for help in that area.
