Unity Path Finding
Jarrod1937
Well, after getting my Hololens and finally attempting to push my code though, I found that the Apex path finding code does not work with the UWP :-(
In order to save myself time in the future, does anyone know if there is a path finding solution for Unity that works with UWP and the Hololens? I'm sure I'm not the only one who needs path finding, especially premade to save time.
OptionsJimbohalo10 ✭✭✭
@Jarrod1937 Just tried Simply A* from Unity asset store. Converted to 5.4HTPb14 and is running in HoloLens Emulator on the WayPoint Scene. Runs identical to Play inUnity. A little cylinder moves round objects to where you left click the mouse and hold. Eventually joins up with mouse pointer.
NO DLLs
What about asset store https://www.assetstore.unity3d.com/en/#!/content/26566
Path Map Generator! The description is good, if its about maps for characters motion
Type "path" and select free in Unity Asset Store
There is so much of path generators. I suppose C# could be true in most cases they probably wont link to HoloLens library, and what so of code could test the package
Unfortunately, that is not advanced enough for what I need. Currently I am using this:
https://www.assetstore.unity3d.com/en/#!/content/17943
Which uses A* and grid graphs that can be generated at run time. This way I can tell an object/agent to go from point A to point B and it will find a path around any obstacles, rather than attempt to simply walk straight through. Path finding is generally the most basic level of any AI that needs to move around the environment.
Unity supports nav meshes, but you cannot generate it at run time. I used Apex path finding, the asset linked above, but it seems to be heavily reliant on non-UWP .NET libraries, and generates hundreds of errors when exporting the project to Visual Studio to load on the Hololens.
Even when you find a package A* path like https://www.assetstore.unity3d.com/en/#!/content/1876
You find its 5.1 and although it says 5.1 and above, its not!
The generated code will rely on net 2.0/3.5 and there is no way to update the code, to generate by Unity .NET 4. Which explains why so many games rely on old Unity versions
NO DLLs
Ah, that's excellent news indeed! I will check that out for sure. Thanks for testing it, a lot of my code was intertwined with Apex, but shouldn't be too much work to get things going.
@Jimbohalo10 , did you have to do anything special to get the path finding to work for the dynamic spatial mesh? I haven't taken a look at it yet, but I will be working on it this weekend and am just curious. It looks like it's default behavior is at runtime, which is perfect, just as long as I can control when it does it (after the spatial mesh is generated and processed into planes).
@Jarrod1937 My initial porting setting are always the same build Player Windows Store, Universal 10,XAML,Local Machine, Unity C# then with Visual Studio 2015 Community
"Master,x86,Local Machine", Build
Followed by
"Debug,x86,HoloLens Emulator", Build
Build -> Deploy Solution,
Debug -> Start Debugging
I have now tried "DynamicTDScene" and this fails due to script Ghost missing
If you delete the Ghost Game-Object entry then Unity spits out an error as well as VS 2015 "Game Object missing"
WayPoint still works fine, GridScene is amazing the Red goes to find Blue over the bridge and Red try's to run from Blue, but cant Blue just chases Red back over the bridge!.
An its working in HoloLens Emulator, just have to fiddle with the inputs, but chase works!
Alright, reached the point where I'm going to try and implement this path finding solution. The guy's code is very nicely laid out, and seems to be designed from the ground up to be generated at runtime. Not ideal for most things, but certainly ideal for us Hololens users!
To not make the same mistake again, I'll start with a simple test and have it path find to chase the player, then I'll build it up from there.
Alright, I think I got it to work with the spatial mesh. I'm taking the spatial mesh, doing plane finding, attaching a box collider to the floor planes via script (took a while to figure this out), generating the grid, and then instantiate a simple enemy (a capsule... nothing fancy, haha). I did a few other things to trim down the example AI script to the bare minimum. It's also important to assign enemies and the player to the ignore tags list, otherwise the enemy will spawn directly in the middle of a no-go zone and it doesn't move.
I am making further progress. It works perfectly in the Unity Editor doing testing, it behaves somewhat differently in the Hololens with the planes generated, seems less precise for some reason. It will cleanly mark tiles as not walkable in the Editor. In the Hololens, instead of making the border of a wall unwalkable, it makes a few feet into the border of the wall unwalkable. I'm wondering if the box collider of the plane prefab is resizing with the scaling I'm using in code. I made a few changes to the code:
I want to move on past this and work more on the fun bits of my game, but I'm trying to get this running fairly smoothly before moving on. Once I've figured out all of the little tricks to getting it to work properly I'll share that info for others needing path finding in the future.
Here's a video showing my progress on the path finding:
https://www.youtube.com/watch?v=t1q_P0VF6dc
Breakthrough! I still have an issue where the doors are covered by the wall planes (even doing subplanes), but I managed to augment the main plane grid graph generation with the spatial mesh. For this I used the spatial mapping collider script, but the tricky part is that in the path finding code I need to define the min and max sampling height for the graph generation. For this, I do plane finding first, I get the floor height (lowest plane marked as a floor), I then pass this height as the lowest height value, and use this value plus 1.8 meters (roughly 6 feet) for the maximum height value. This allows the grid graph to capture details of the room while avoiding the ceiling as a component in the calculation. I still require using the walls, as my guy will happily walk through a wall with only the spatial mapping, but the two combined work fairly well. I'm happy enough with it now I can post a video of the progress and move on to more exciting aspects.
@Jarrod1937 : thank you for sharing your progress.
For my project I also need to use pathfinding on the Hololens for a digital character to navigate through the physical space, and I'm playing around with A* right now.
Any chance you'd be willing to share your work in form of a step by step tutorial?
(I couldn't find anything on wikiholo.net yet)
I used the layered grid graph and directly the spatial mesh without generating planes as you did. It kinda works, no problemo with the walls.
What I am struggling with is generating off-mesh links. In one of the demo scenes there are those animation links.
Unfortunately, to make a star work on the hololens I had to do this: http://forum.unity3d.com/threads/a-pathfinding-failed-to-run-serialization-weaver-when-building-for-windows-store-wp8-1.377737/
After doing that this demo scene doesn't work anymore; not in the editor and not on the hololens.
Any ideas on how to make the character jump on and off the table?
A* has been updated a few times and I just downloaded the newest free version and with a minor change it seems to work fine with my holographic app.
