Referencing .NET DLLs from HoloLens UWP?
I have some precompiled 64-bit .NET 3.5 DLLs. I know that can't work on HoloLens since it is 32-bit. But, can I just recompile for 32-bit? does it also need to be .NET 4 or 4.5? Or will nothing but UWP work? If none of that works, I vaguely recall hearing somewhere about a UWP conversion for older apps... Is that possible?
Would think it would have to be 32-bit x86 .NET Core (AKA 5)...or at least that would be something more likely to work. Some times for common libraries you can use Nuget and not have to think about it... I was trying to get a 32 bit .NET 4 dll to work but was not successful with that one at least.
I built a 32-bit x86 .NET 3.5 DLL and referenced from a UWP app and deployed it to HoloLens and that works. Unfortunately, it looks like there are Win32 native calls in the DLL I am trying to use, so it's not truly managed. Apparently, if you have Interop in the DLL, it won't work.
Also, it appears that Project Centennial can't help because it wraps whole apps from the setup msi, so it looks like there is no way to UWPify a DLL that isn't pure .NET already.
https://msdn.microsoft.com/en-GB/library/windows/apps/mt592904
win32 API for UWP
