Microsoft HoloLens Windows Store App
Hopefully this hasn't already been asked, but if it has, please direct me there. The Microsoft HoloLens Windows Store App is a cool idea, but there aren't many directions on how to use it. For example, what type of wifi will the app work with? We have a wifi at my work that requires a username and password, but that wifi isn't able to be connected to due to strage restrictions at my work. Due to that, we have to use the less secure wifi (connect and it opens a browser where you "accept" the terms and then you connect). This second one seems to not work due to the lack of security. Any ideas?
There is an application for a desktop computer called "Microsoft HoloLens Windows Store App." It allows you to use the device portal to connect to the hololens. I found out how to get it to work on my home wifi. I think that my work wifi needs special permissions.
Hey collin
I'm not sure I understand what you are asking. As long as you are connected to the internet, the Store, and the apps in the store should work regardless on how you are connected.
I might be missing something from your question...
