Minimal Implementation of Surface Mesh To Planes?
I'm still trying to learn all the components in the HoloToolKit. The last major piece that I have not gotten working is surface meshes to planes. I've gone through "Holograms 230" but I want to do this from scratch in my own app.
I've dragged in a SpatialMapping prefab (and it comes with a spatial mapping observer and manager), and then I dragged SurfaceMeshesToPlanes onto my main camera. I create another script that instantiates a SurfaceMeshesToPlanes object and I call .MakePlanes() on that object. I'm running this in the emulator with a room loaded and I do see the spatial mapping but I never get any .ActivePlanes. I know it's not a good idea to call this from a foreground thread but I was hoping I'd be able to do that in a simple app.
Which prefabs and scripts do I need to get an absolute minimal app to detect planes?
OptionsSimusid ✭
For the coders here (most of us), that awesome incredible feeling when you get something working! My working trivial implementation is a new project, drag in Spatial Mapping component, plus I copied the PlaySpaceManager.cs script from Holograms 230 and attached it to my camera. The only mod I made was to remove the line:
SpaceCollectionManager.Instance.GenerateItemsInWorld(horizontal, vertical);
because it is specific to that project. While I didn't get it working in the emulator, my code did work FINE on the device and detected my horizontal and vertical surfaces! Yes, I'm very excited. This is exactly how I want to spend my 4th of July (not joking!)
Cheers!
6
Cheers!
