Unsafe Code Error (Sharing folder)
Hi All,
I want to explore deeper about Sharing from HoloToolKit folder. Unfortunately I found Unsafe Code errors from several code belongs to Sharing folder (AnchorDownloadRequest, ImageTagManager, NetworkInMessage, NetworkOutMesage, RoomManager, TagImage, VisualPairConnector). In the Asset folder I already make sure it has the .rsp files (csc, fmcs, smcs). Any suggestion how to solve this issue? Seems like there is no clear solution from previous thread as well.
Thanks for your attention.
Cheers,
Those files need to move from the HoloToolkit\assets folder into your main project's assets folder.
@markus when you dragged the HoloToolkit into the Unity Asset folder did you also drag the .rsp files along?
@mARkus,
This is due to the fact that the VS project settings are not properly set. I was having the same problem:
Open the project properties for SessionManagerUniversal.UI, and go to the Build tab. Check/enable "Allow unsafe code" for each configuration and platform you intend to build for (total of 6 by default, if you use the build script).
HTH,
~h
