How could I add a new third party dll into the script? Unity will say not found when build
I want to add some 3rd party dll like microsoft.json.dll (which is truly 3rd party dll) and like 'System.Data.Services.Client.dll' which is dll in GAC.
Problem I met with is, when we add any additional dll into script, unity will build break saying not found such namespace.. then I add those dll under assert folder, this time, unity can load it, but then it start reporting not able to load those assemblies that this dll depends on.
How could I make it work correctly? is there any way that I could make unity load dlls in GAC?
@Solluna if your dll is compatible with Unity's version of mono (I believe it is still version 2.X) then you should be able to have Unity add the necessary reference by placing a copy in the Unity Project's Asset directory as described here.
However, if you DLL requires more current .NET or UWP support, then you will need to wrap your calls to that dll in #If statements such as
#if !UNITY_EDITOR
to avoid errors in the Unity editor and you will want to add the necessary reference to the UWP Visual Studio solution that Unity generates when you use the Unity Build functionality.
