Microsoft office support - especially outlook support - Holo Outlook reader / Doc reader
Is there any possibility to read outlook mails and word documents etc... through hololens platform?
Yes, you can install Outlook or Word from the Store.
Great. Thanks. I should have checked at the store before asking. My apologize. Thanks Alex.
I'm getting error code 0x80240024 when attempting to install any of the Office apps through the Store on HoloLens. I already reset the device to factory settings and have checked for updates, but it still is not allowing me to install any of the office apps (outlook, powerpoint, words, or excel). What's going on? There's no mention of this error code anywhere that I can find.
Make sure Windows (Settings-->Update & Security-->Advanced Options) is set to Automatic. Or at least maybe that'll help. Good luck!
I suggest you try under Windows 10 if you think have problems with the store and remember HoloLens Emulator cannot install Windows Store apps.
Check you are running the latest Version of HoloLens software
Windows Holographic May 2016 first flight
@Talon,
In my situation, it went fine. Please make sure you had paired the lens with computer also. I am not 100% sure of this. But its worth the try.
