Stream stereo pair to HoloLens
I'm interested in streaming a stereo pair, JPEG sequence to the HoloLens for prototyping purposes. @neerajwadhwa mentioned that this may already have been done before. I'm curious if anyone can provide code samples or a more general HOW TO?
My ideal would be to have a light weight application on the HoloLens that simply displays a left and right image in full screen. At the moment I don't think I'm too concerned with performance, I would just like to experiment with off device rendering.
Seems possibly related to this user's question: https://forums.hololens.com/discussion/comment/6023?
I don't think controlling the individual displays is possible on the HoloLens. The process of separating the display outputs for each lens is done internally and likely not available for developers.
@jvanderdoes streaming JPEG to HoloLens is possible but I have not tried this myself and don't have any public samples to share at this moment.
As @AlexD mentioned, you don't have access to left and right eye cameras.
@neerajwadhwa
I like to go the way in reversed direction: Recording stereo video from HoloLens.
Seeing the video "HoloLens Spatial Mapping Points - Sphere Extraction", we can notice that the right eye video is being recorded.
Or, as the video "Improvements by Google Project Tango", the neutral central view is OK.
@AlexD perhaps the best way to do this would be either a DirectX or Unity app with texture mapped image planes. Sound about right?
In unity I would agree, but then again I'm not sure about if you could do it with a custom shader in Unity., However, in DirectX it's totally possible. Unless I'm doing something extremely wrong and I've hacked my way into this... You CAN display different images to different eyes in Hololens, however you have to use DirectX - C++, and create your own pixel and vertex shaders. I found this out by accident trying to display 3D Words on the screen, see this post here
You can control stereoscopic views which you noticed in the Recording software as noted above.
I'll create a post about this later.
Caveat... the experience in my oppinion gives a headache which I would expect over prolonged use due to the strain on 1 eye vs another. So be careful.
Dwight Goins
http://dgoins.wordpress.com
@Dwight_Goins_EE_MVP that looks really promising. Do you have any code you're willing to share?
I'll post a sample on the github repo. Check this post out.
https://forums.hololens.com/discussion/1852/hololens-directx-tutorials-and-samples/p1?new=1
Dwight Goins
