HoloLens Emulator Stuck OS is starting...
OK, I have tried every conceivable thing I could find to try and fix this issue short of completely refreshing my install of Windows 10. I cannot get the HoloLens Emulator 10.0.14393.0 to start in VS.
This just started happening out of the blue on my Surface Book after installing Anniversary Update.
I have tried
- Deleting the Hyper-V VMs/Virtual Switches/ Runnding XDECleanup
- Setting the XDE allowed in the firewall & disabling the firewall
- Uninstalling all emulators, reinstalling
- Installed the latest updates to VS
- Set the network connections for Hyper-V to "Private" instead of "Public" Network Category
- (Reboot many times - of course)
- Disabled use of the physical GPU in Hyper-V for remotefx
I am at a loss for what else to try. I really do not want to wipe my OS and start over if possible.
Optionsrunamuck ✭
@Dwight_Goins_EE_MVP Thank you for the input!
I eventually fixed this by completely removing the Hyper-V features from Windows - rebooting - adding them back - rebooting and then it worked.
7
Mine takes an extremely long time to boot as well but eventually it comes up. I stop the build process, and wait for it to come up. I believe it's checking the gpu for capabilities. If you have a dGPU on the surface book, then goto the NVidia control panel and tell it to use the integrated graphics for the XDE.exe app. This should make it start a lot faster. Review this link for more.
Dwight Goins
http://dgoins.wordpress.com
