HoloToolkit Build errors
I've been trying my best to compile the HoloToolkit/Sharing source code, and I keep running into errors where source file references are missing (even though they get generated properly), missing SharingClient.pdb, and other missing files.
Severity Code Description Project File Line Suppression State Error CS2001 Source file 'C:\Users\ussho\Desktop\HoloToolkit-master\Sharing\Src\Projects\SessionManagerUniversal.UI\..\..\generatedinterface\csharpapi\AnchorDownloadRequest.cs' could not be found. SessionManagerUniversal.UI C:\Users\ussho\Desktop\HoloToolkit-master\Sharing\Src\Projects\SessionManagerUniversal.UI\CSC 1 Active Severity Code Description Project File Line Suppression State Error Could not copy the file "C:\Users\ussho\Desktop\HoloToolkit-master\Sharing\Src\bin\Debug\Win32\ClientWindowsCSharp\SharingClient.pdb" because it was not found. SessionManager.UI C:\Program Files (x86)\MSBuild\14.0\bin\Microsoft.Common.CurrentVersion.targets 4136 Severity Code Description Project File Line Suppression State Error C2220 warning treated as error - no 'object' file generated CommonUniversal c:\users\ussho\desktop\holotoolkit-master\sharing\src\external\raknet-4.081\include\source\SocketIncludes.h 37
Stephen Hodgson
HoloToolkit-Unity Moderator
Optionsqdkid ✭
I had similar trouble and figure out the solution. Open the HoloToolKit.Sharing solution file in VS 2015 Update 3, then right click on 'SessionManagerUnivresal.UI' project->Manage NuGet Package. You will see 'Microsoft.NetCore.UniversalWindowsPlatform', update the version to 5.2.2. You will be prompted to download etc. Then build again will solve the missing files.
2
what scripts are you using to build? My best recommendation is to build all dependencies then open the solution in visual studio and build from there
@AlexD I've tried:
BuildDependencies.bat
BuildSharingLib.bat
BuildAll.bat
and in VS I opened the HoloToolkit.Sharing.sln and tried building all dependencies as well. That's actually where I'm getting the errors.
Stephen Hodgson
I am also having this problem. Building the dependencies works fine but building the libraries gives me with numerous errors all similar to this but with different .cs files:
CSC : error CS2001: Source file 'C:\HoloToolkit-master\Sharing\Src\Pro
jects\SessionManagerUniversal.UI....\generatedinterface\csharpapi\Imag
eTagLocation.cs' could not be found. [C:\HoloToolkit-master\Sharing\Src\
Projects\SessionManagerUniversal.UI\SessionManagerUniversal.UI.csproj]
Thanks @qdkid fixed my issue.
That and installing Java 8.
Stephen Hodgson
