Unity - Spatial mapping, determine the "floor" of the room?
Hi!
I have a simple cube and I want that to always be aligned with the floor of my room once the game starts.
Now..
First of all.. is there a simple "editor"-way of doing this? (for instance.. if I place the cube at position x,x,x.. can I then be sure that the cube always "spawns" on the floor?
Or is there any "programmatic way" of how to determine which part of the spatial mesh is the floor?
Hi Inx51! Yes, you can use the SurfaceMeshestoPlanes script as part of the Holotoolkit to generate planes for the ceiling/walls/floor in your app. You can then reference these throughout your app. Please see the Holograms 230 tutorial here to get a better idea about how that works:
https://developer.microsoft.com/en-us/windows/holographic/holograms_230
Good luck!
