Does the Hololens Emulator store persistent data?
Using the FileAccess sample from the Windows Universal Samples Master download, it is possible to demonstrate that if you use a PC as well as other platforms with UWP, you can successfully retrieve your data later. I have done this and it works fine on my PC. However when I tried adapting the code to run on the Hololens emulator, the file I wanted to retrieve did not exist. I use
string writetoken = StorageApplicationPermissions.FutureAccessList.Add(writefile, writefile.Name);
to store the StorageFile writefile and to read it:
readfile = await StorageApplicationPermissions.FutureAccessList.GetFileAsync(token); if (readfile == null) return; readfilecontent = await FileIO.ReadTextAsync(readfile);
as I originally saved the metadata as just the name of this file (writefile.Name), I can then identify the token from going through the list of files available by comparing this name and retrieving the targeted token:-
static public string Find_FALtoken_from_accesslist_metadata(string filename) { var fname = filename.ToLower(); string token = ""; AccessListEntryView entries; entries = StorageApplicationPermissions.FutureAccessList.Entries; foreach (AccessListEntry entry in entries) { var name = entry.Metadata; if (filename.ToLower().Equals(fname)) { token = entry.Token; return token; } } return token; }
This process works fine used from my PC. But when incorporated into my Hololens app using the Hololens Emulator, it does not. Is this correct? It is probably wrong to expect it to but I hope someone can tell me definitively. Thanks
OptionsAlex480 ✭✭
How "persistent" do you mean? The emulator is known for "resetting" itself on every VM reboot - so all apps and data gets lost on that. From my experience it also seems that after few days it looses things as well. But assuming you keep it up and running it should keep the files. I have been successful with storing files in the app data folders - not sure if your case is more specialized or different in any way.
The File Explorer in the Device Portal is also a great tool to see if the files exist where one expects them.
That seems to answer my question precisely. I guess it should work with file saving provided you do lose the emulator. I shall try that now. Thank you for getting back to me so promptly.
