Interpolator (in HoloToolkit)
Hi all, I'm trying to get the interpolator script working and am having some trouble understanding it.
For instance if I wanted to move a cube from it's current position to a target position smoothly, where exactly would I attach the script and how would I call it?
I'm confident that I need to be working with:
public void SetTargetPosition(Vector3 target)
but am just not sure exactly what it looks like to send the Vector3 data to this script.
Thanks for any help!
EDIT:
Here is the interpolator script for those who haven't seen it
@seanicboom,
You can attach the Interpolator script to your object in the Inspector or you can add it via code.
I like to attach scripts in the Inspector to help me get an overview of what scripts each of my GameObjects use.
Here is how I used it in a project I am developing:
Hope this helps!
David
