How to project a texture on the SpatialMap?
I'm trying to get the Unity Projector to project a texture on to the world spatial map. I've changed up materials on the Spatial map to make sure it wasn't an issue with alpha/occlusion. Any ideas?
Optionscpeter ✭
Yeah looked into those and it seems like the projector doesn't project on surfaces without a texture.(i.e. There is nothing to project on.) Still not sure why base shaders on the Spatial Map had no effect though.
I think my best bet is going to a Decal type system. Simple and decently cheap on usage as far as I know.5
@cpeter,
I have not used the Projector before, but the Unity documentation calls out that you need to use a special shader for it to work and set the texture's material of the projector to 'clamp':
https://docs.unity3d.com/Manual/class-Projector.html
Have you tried loading a captured room file into Unity and testing the Projector within the editor? Does it work in the editor but not on HoloLens?
If you're running with our recommended quality settings (Fastest), then shadows are turned off by default. Lighting and shadows are expensive to run on the HoloLens, along with post-processing camera effects that you'll find in Unity's standard assets folder. The Terrain system is usually too expensive to run on HoloLens, and Projector might suffer from the same limitations.
