Unity performance issues with large (full-screen) hologram
Hi all,
I've started the process of bringing our app up to the requisite 60 fps, and I've been having some strange issues. It seems I simply can't draw a full screen's worth of pixels with the holotoolkit-unity/standardFast shader - no matter how minimal the scene:
Repro steps
Create a new scene in Unity
Setup for Hololens (Holotoolkit settings/camera etc)
Delete all lights
Add FPSCounter prefab
Create a default sphere (GameObject ->3D Object->Sphere)
Set sphere position to (0, 0, 2.35), reset any other transform components
Create a new material (Assets->Create->Material), assign a Holotoolkit->StandardFast shader and apply to the sphere.
Add the following script to the sphere:
public class TestPerf : MonoBehaviour {
void Update () {
float sinScale = (float)Math.Sin(Time.time);
transform.localScale = new UnityEngine.Vector3(sinScale, sinScale, 1.0f);
The point of this script is simply to create a varying draw load – the sphere will go from 0% of the screen to nearly 100%.
Build, set to release, deploy to device. Watch the sphere scale in and out, and notice the FPS drop to 30fps each time the sphere fills the viewpoint.
Note: I can maintain 60FPS with the unlit shaders. However, it seems rather strange that the GPU could not handle the load of a single object/no lights/no textures on the standard shader. Is this expected behaviour?
Whats really strange is that we drop to 30fps over this trivial load, but as I load the scene up with the rest of the scene (100s of thousands of poly's) it stays pegged at 30fps and doesn't miss a beat.
I would suspect the FPSCounter prefab was not 100% accurate, but the scene definitely feels like 30fps when it says 30fps.
OptionsMrSteveT ✭
In the end, I re-wrote all the sharers to minimal implementations with my own lighting equations, and achieved 60fps this way. Possibly the surface implementation in Unity is not very efficient - but in any case, to squeeze max perf I would suggest writing your own shaders to get that instruction count as low as possible.
7
Make sure you are building in Release mode (in Visual Studio) rather than Debug - it made a HUGE difference for me, far more than with any other device I've used. My app went from choppy as heck to smooth as butter.
Thanks for the suggestion - yes, I saw the difference between debug and release too (and was surprised it was so big). But this is different - the bottleneck is (almost) certainly the fragment shader, so even if I was running in debug mode it shouldn't affect the GPU's performance.
@MrSteveT did you set the project quality settings for Unity to Fastest?
@Holosheep - yes, I set the quality settings to fastest. I also tried disabling any other performance related items. As far as I can tell, there is a single instruction being executed per pixel shade to get 60fps.
I guess this is -not- an expected result then? I'll keep digging to see if there is any further options.
I've had similar issues MrSteve, and ended up doing the same.
Stephen Hodgson
HoloToolkit-Unity Moderator
