Shift operator used in SpatialMapping.cs
Why is a shift operator being used in the Awake method? all it is doing is setting the PhysicalRaycastMask to int.MinValue, and why use shift as opposed to a int.MinValue?
Optionsahillier mod
We bit shift the index of the spatial mapping layer (31) to get a bit mask, which will allow us to cast rays only against colliders in the spatial mapping layer.
LayerMasks do not have to be limited to a single layer. You can combine multiple layers to cast against. For example, we could do something like this to combine layers 31 (spatial mapping) and 5 (UI) together:
var layerMask = (1<<31) | (1<<5);
The answers to these Unity posts are great and should help explain further:
http://answers.unity3d.com/questions/177206/raycasting-and-layermask-question.html
http://answers.unity3d.com/questions/122586/layermask-vs-1ltlt-gameobjectlayer-.html1
Thanks for the answer!
