Avoid Pinned Tile Name
How can I avoid that a name is shown on my app tile when it is pinned to the HoloLens start menu? I removed ShortName from the manifest completely but then it shows the DisplayName. ShowNameOnTiles is also empty. Using a space like ShortName=" " fails the build.
I just don't want a name string on my pinned tile since the logo icon already contains the app name.
René Schulte | Director, Immersive Experiences | Microsoft MVP Windows Development
www.identitymine.com | http://blog.rene-schulte.info
@Rschu You said you had edited the string values in your applications Package.Appxmanifest Application or Packaging tabs, or did you edit the manifest xml directly?
@WithinRafael We understand your concern, but I don't think the HoloLens supports magnifiers, screen readers, nor high contrast mode. Also, the pinned tile's application target probably isn't tied to what @Rschu is describing, so you won't get a bad target when trying to load tile data.
Stephen Hodgson
HoloToolkit-Unity Moderator5
Does the app have a tagline you could use there instead?
That's a terrible idea and glad it's not supported. (Am frankly shocked to see such a want from IdentityMine.)
I suspect if this was supported, you'd break screen readers, not behave correctly on font size/color changes (e.g. high contrast mode), be less legible than usual under Magnifier, and generally just make a mess of Start.
I believe there are also cases where tile assets may be lazy loaded (or fail to load). In this case, we'd literally have a blank tile.
Keep calm Rafael. It is not about the app list, just the pinned tile. I understand your concern there but no need to be aggressive. There's always a valid reason from a designer standpoint and also for brand identity. Not so much shocking.
Stephen Hodgson
I edited the Package.Appxmanifest XML directly in the VS solution Unity generates. I was following the Appxmanifest docs on MSDN. No luck so far.
The same comments above apply to the pinned tile.
