Any idea why my Spatial Mapping Script Seems To Place My Objects In The Floor a few inches
Anyone else experience this? I'm using the items In Holo Toolkit. I have decent size box colliders around the objects I'm placing but they still seem to be placed inside the floor as opposed to on top of it.
@imagineholos check this post here and see if that sounds like what you are running into and if the explanation helps.
@imagineholos make sure your objects pivot is at the bottom of your object where it should meet the floor.
Stephen Hodgson
HoloToolkit-Unity Moderator
This might be it. I came across this article awhile ago the one listed above. It's what made me create a wrapper. Maybe I applied my Tag script to the base and not the outer wrapper. I will have to modify it and see.
