multiple GestureManipulator in a scene
I have multiple GestureManipulator in a scene but want them to move individually. any advice on how to do this?
Hi felsiska,
how do you determine which object you want to move?
I do it via Focus. I use the GazeManager and GestureManager from HoloToolkit for Unity and add a script to the movable objects that enables the GestureManipulator upon GazeEnter and disables it upon GazeLeave.It could look like
public class FocusedObjectReceiver : MonoBehaviour { [Tooltip("Object color changes to this when focused.")] public Color FocusedColor = Color.red; private Material material; private Color originalColor; void Start () { var manipulator = GetComponent<GestureManipulator>(); if (manipulator != null) manipulator.enabled = false; material = GetComponent<Renderer>().material; originalColor = material.color; } public void OnGazeEnter() { var manipulator = GetComponent<GestureManipulator>(); if (manipulator != null) manipulator.enabled = true; material.color = FocusedColor; } public void OnGazeLeave() { var manipulator = GetComponent<GestureManipulator>(); if (manipulator != null) manipulator.enabled = false; material.color = originalColor; } }
HTH,
Lars5
Hi felsiska,
It could look like
HTH,
Lars
@Lars_Roith
thx for the advice. works now with similar script.
