Anyone else having this problem
After the recent update to the Hololens Store whenever I try to locate an installed APP the list of APPS keeps moving all over the place. Example I have installed most of the significant apps from the store but when I try to gaze at ( example Skype) the cursor will jump up and down to another app. I have tried recalibration gaze, steadying my gaze and using the up and down arrows on the right but the page keeps jumping all over the place. My best estimate is that I have no more than 15 apps installed
If I am posting these questions in the wrong area pls direct me to the correct forum. I am not much on posting on forums as I am browsing them for help and information.
Ron
Optionsutekai ✭✭✭
You can use the Windows Device Portal to explore performance issues on the hololens. This sort of sounds like what is happening, that your FPS is slowing down for some reason.
Help with APPs listing
