Unity vs DirectX performance
Hi all,
I have been researching HoloLens development for a while now. I noticed there are two different ways of developing for the HoloLens, Unity and DirectX. However, none of the sources speak about performance of Unity compared to DirectX. Does DirectX development allow for more performance due to less overhead of the Unity game engine?
Some sources I found:
- https://medium.com/@turleyn/hololens-gpu-experiments-e4ed14201df6#.92hhmm6g7 (not sure if this is written in Unity or DirectX).
https://developer.microsoft.com/en-us/windows/holographic/performance_recommendations
(this seems to be for DirectX development)https://developer.microsoft.com/nl-nl/windows/holographic/performance_recommendations_for_unity (unity performance recommendations).
- http://windowscomments.com/?p=2110 (this one seems to be outdated already).
And if DirectX programming allows for more performance, is it worth the trouble? (Of course it depends on the type of application also) I have done some OpenGL programming in the past, but never DirectX (neither have I programmed in Unity before).
I am not exactly sure of the application I am going to create, but it probably involves the rendering of 3D CAD models.
Bram
Hi @Barmyard,
DirectX is the closest code you can get to the metal with Holographic development, and to be specific C++/DirectX. What I mean by this is as far as performance is concerned, C++/DirectX will have the least layers/frameworks which usually means better performance.
However this is not always the case, performance is based on many aspects as you point out in the articles above. A Holographic application has many points of contention where performance can be an issue. Shaders, Custom Logic, Physics, Spatial Sounds, Voice Recognition, Gaze, Gestures, RAM, latencies (such as network) and the list can go on and on.
The HL Team has built multiple showcase applications for the HoloLens using Unity as the development platform, One such application is the Galaxy Explorer and they have made conscious decisions for performance especially when attempting to display thousands of stars in the galaxy.
It has been explained to me that you can get good performance for the most complex type of application using Unity, and it is an adequate platform.
As far as DirectX, you can clearly get the best performance because it's less levels of indirection but at the cost of development time. Here's a good video of general DirectX performance vs XAML
I stress, the development experience is not the same. I'll give you an example, For a person with no Unity experience, they can get a cube spinning in mid air with your own texture in like 1 hour as a tutorial in Unity. Doing the same in DirectX programing, with the same newbie level of expertise will take at least 1 whole day (24 hours) and that's if they don't run into any issues nor give up trying.
Dwight Goins
http://dgoins.wordpress.com3 -
Another point to make here is that you can learn HLSL (Shaders) and create your own Shaders (Vertex, Geometry, and Pixels) and use these in Unity. You can also mix match your development. You can think of Unity like a UI Front End, with a Physics Library, Sound Library and packaging tool. You can then create C++/C# libraries to handle Networking, More Complex Audio samples, and etc and use these components inside of a Unity application.
On the flip side, you can also build Unity meshes, and textures, and export these objects as models to use inside C#/C++ DirectX HoloGraphic applications if I'm not mistaken.
To determine if this is worth it, it depends on your application, purpose, and team building it. Take a look at some of these samples in DirectX here and here.
Dwight Goins
http://dgoins.wordpress.com5 -
OptionsJimbohalo10 ✭✭✭
@Barmyard said:
I am not exactly sure of the application I am going to create, but it probably involves the rendering of 3D CAD models.Thanks,
BramHi Bram,
There is a article all about Unity 3D model importAlthough you might think the speed of DirectX is important. The vast array of software available in the Unity Asset store will probably bring you round to getting quick results from adapting others work. Importing is easy Import 3D, even dynamically at run time. There are amazing free apps for 3D editing apps KitBash
Back a while ago I easily converted this converting-unity-5-destroyed-city
in under an hour and I had only just started Unity/HoloLens then.Direct X conversion would take weeks. Well you could do the complex work in DirectX and call your code as a plugin in Unity
Really what you need to start is a PC with QUAD I5 NVidia GT750 at least 8GB memory or better to run with the Emulator and see how fast the Visual Studio DirectX Holographic template is compared with Unity doing a similar thing. You will find that when built the Unity WSA Player optimises the code very well, better than most people could as it relies on calling highly optimised libraries.
1
For development of HoloLens using OpenGL, please use Microsoft Angle for Hololens
For demo using Microsoft's Angle4Hololens, check:
Part 1.
Part 2
Part 3
Hi @Barmyard,
Dwight Goins
Dwight Goins
Hi Bram,
@Dwight_Goins_EE_MVP
Thank you very much for your extensive answers! It seems to me now that the performance of Unity should be enough. I didn't know that creating your own shaders in Unity is also possible. I am going to work on a master thesis project on my own, so it's better to avoid the use overhead.
@Jimbohalo10
Thanks for your answer! It seems to me that Unity will do in my case.
Awesome community guys, keep it up
