Camera and cursor positon
Hi all,
I am trying to create a scene which has a plane (surface not airplane) and a ball on top of it.
After adding the plane with scale 1,1,1 i failed to see it because the camera was positioned on 0,0,0. so setting the camera to 0,80,-20 and rotation to down 45 i managed to see the plane.
The problem was that the cursor (import from HoloToolKit) doesn't hit the surface since the camera is too far from the plane (I am using emulator).
Is there a way to set cursor distance so it always hit the plane even if it is far?
By setting camera rotation to specific, will it affect how the user sees the hologram? will he always see the hologram in the rotation set by Unity?
the Hololens is pretty much the centre of the universe so hence we place it at 0,0,0 so that everything else it based around that. It is also handy in calculating how far something is from the hololens, ie 0,1,0 would be 1 metre up from the hololens and 0,0,1 would be 1 metre away from the hololens.
I would suggest that you modify the cursor script and if it touches the plane (with a trigger collider on it) move the plane down where the cursor touches
creative mind, free thinker, dreamer, maker, mostly working on games and doodling around with gadgets, Sphered Cazual/Elite/Master of the Universe/Dad/Husband @mariovermeulen
Hello !
I have the same issue, did you figure it out ?
Thanks.
Not yet.
First of all the camera should stay at 0,0,0 as that it where your head would view from, try setting the plane transform to 0,0,5 and the rotation to -12,0,0.
Alternatively you could also use a shader which renders on both side, you find on a plane the default render is with cull back, you could customise one of the shaders to use cull off but then the lighting will be off.
also to easily see what your camera see in the editor windows click on your main camera and then select menu option GameObject\Align View to Selected this will make your editor window see what your camer sees.
One other issue could be that you dont have a collider attached to the plane, which then makes the cursor not see the plane or you haare using the Cursormanager and have not set your object to the Interactible layer.
anyway just some thoughts or your possible problem
Hi SpheredCazual,
I am trying to port Unity "roll a ball" tutorial project (https://unity3d.com/learn/tutorials/projects/roll-ball-tutorial) to HoloLens project. In this tutorial there is a ball on the plane. by rotating the plane will cause the ball to move down.
I want to move the ball based on the cursor.
What will user see if the camera is not set to 0,0,0?
Should camera always be set to 0,0,0?
Great now i got it working!!!.
Instead of using trigger (causes ball to fall from the plane) and moving the plane, in if(GazeManager.Instance.Hit) I simply incremented the y position of the cursor by 0.1f only if collider.name == "Ground".
Excellent glad you got it working!
