Make an object stop when in contact with a wall
I have an object that i can use manipulation on and move arond with tap and hold. Right now the object is jumping around when i "press it" against the spatial mapping. I want to make it so that the object just stops when it comes in contact with the spatial mapping. i have tried a few different things with OnCollisionEnter but nothing has worked. Is there a method for this I am missing?
    @SuperKodama have you looked into Rigidbodies and physics?
    @HoloSheep I have a Rigidbody with colliders on. It works if i just use addForce and make the objekt fly on its own into the wall. Should I try to use addForce instead of transform.position with manipulation as well?
    @SuperKodama instead of transform.position have you tried Rigidbody.MovePosition?
    @HoloSheep Hm, It worked a little better. The object doesnt rotate in the lagging anymore. Is there a way to calculate the distance from the object to the closest part of the spatial mapping? I was thinking of using that in an if statement and check if the new position i to close to the spatial mapping and if so not move?
    edited October 2016
    DELETED: Nevermind, I should read the questions better.
