Spatial map how to modify
when I input handler, the sample come up "Render mesh data as a surface, visualizing the spatial map as an overlay on top of surfaces" but I need the mesh skip the other things on the desk what should I do?
thanks
    @wangwei,
    The Holographic Academy Spatial Mapping course demonstrates a method to modify the mesh.
    I recommend looking at the Processing chapter, specifically the RemoveSurfaceVertices.cs file for how we removed portions of the mesh.
    David
    H i@David
    First of all thank you very much for your answer to this question.
    Now, I use the DirectX11 example(HolographicSpatialMapping), I want to change this case, I want to get a single effect.
    Do you know how to change?
    trzytrzy ✭✭✭
    @DavidKlineMS said:
    @wangwei,
    David
    Hi David,
    I've observed that RemoveSurfaceVertices is very aggressive -- to the point that it removes huge chunks of the spatial mesh that are not bound by surface planes when SurfacePlane objects are used as the bounds. I think this is because collider.Contains() uses an axis-aligned bounding box, not the actual collider volume in world space. Or am I mistaken? If so, then I can't easily explain why RemoveSurfaceVertices culls out so much geometry and will have to debug further.
    Bart
