Spatial map how to modify
when I input handler, the sample come up "Render mesh data as a surface, visualizing the spatial map as an overlay on top of surfaces" but I need the mesh skip the other things on the desk what should I do?
thanks
@wangwei,
The Holographic Academy Spatial Mapping course demonstrates a method to modify the mesh.
I recommend looking at the Processing chapter, specifically the RemoveSurfaceVertices.cs file for how we removed portions of the mesh.
David
H i@David
First of all thank you very much for your answer to this question.
Now, I use the DirectX11 example(HolographicSpatialMapping), I want to change this case, I want to get a single effect.
Do you know how to change?
Hi David,
I've observed that RemoveSurfaceVertices is very aggressive -- to the point that it removes huge chunks of the spatial mesh that are not bound by surface planes when SurfacePlane objects are used as the bounds. I think this is because collider.Contains() uses an axis-aligned bounding box, not the actual collider volume in world space. Or am I mistaken? If so, then I can't easily explain why RemoveSurfaceVertices culls out so much geometry and will have to debug further.
Bart
Bart
http://trzy.org
