Microsoft Hololens Emulator installation error messages
... roperty(S): SOURCEDIR = C:\ProgramData\Package Cache{914A5C4B-0149-471A-9423-D29BB0A41864}v10.1.11082.1039\Installers\
Property(S): SourcedirProduct = {914A5C4B-0149-471A-9423-D29BB0A41864}
Property(S): ProductToBeRegistered = 1
MSI (s) (A8:24) [18:26:35:661]: Note: 1: 1708
MSI (s) (A8:24) [18:26:35:661]: Note: 1: 2205 2: 3: Error
MSI (s) (A8:24) [18:26:35:661]: Note: 1: 2228 2: 3: Error 4: SELECT Message
FROM Error
WHERE Error
= 1708
FROM Error
WHERE Error
= 1709
MSI (s) (A8:24) [18:26:35:661]: Product: Microsoft Emulator 10.0.11082.0 -- Installation failed.
MSI (s) (A8:24) [18:26:35:713]: Windows Installer installed the product. Product Name: Microsoft Emulator 10.0.11082.0. Product Version: 10.1.11082.1039. Product Language: 1033. Manufacturer: Microsoft Corporation. Installation success or error status: 1603.
MSI (s) (A8:24) [18:26:35:777]: Deferring clean up of packages/files, if any exist
MSI (s) (A8:24) [18:26:35:777]: MainEngineThread is returning 1603
MSI (s) (A8:98) [18:26:35:792]: RESTART MANAGER: Session closed.
MSI (s) (A8:98) [18:26:35:792]: No System Restore sequence number for this installation.
=== Logging stopped: 2016-03-31 18:26:35 ===
MSI (s) (A8:98) [18:26:35:810]: User policy value 'DisableRollback' is 0
MSI (s) (A8:98) [18:26:35:810]: Machine policy value 'DisableRollback' is 0
MSI (s) (A8:98) [18:26:35:810]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (A8:98) [18:26:35:811]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (A8:98) [18:26:35:812]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (A8:98) [18:26:35:814]: Destroying RemoteAPI object.
MSI (s) (A8:30) [18:26:35:814]: Custom Action Manager thread ending.
MSI (c) (60:4C) [18:26:35:814]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (60:4C) [18:26:35:861]: MainEngineThread is returning 1603
=== Verbose logging stopped: 2016-03-31 18:26:35 ===
Requesting assistance to resolve this. Thank you in advance.
I have the same problem
I found the solution. Go to "Windows feature on and off" and find position "Hyper-V'. It need to be checked, when you do that everything will go ok from now on
Only "64-bit Windows 10 Pro, Enterprise, or Education" have Hyper-V. The Home edition does not support Hyper-V. Installing the HoloLens Emulator will fail on the Home edition.
