DEP6100 error with emulator
I get the following error when trying to deploy the sample Origami project to the emulator. I've tried un-installing and re-installing the emulator without effect.
I've seen others mention this error in the forums, but haven' t found a definitive answer -- has anyone been able to work through this?
_DEP6100 : The following unexpected error occurred during bootstrapping stage 'Connecting to the device 'F957827B-6FC8-4538-A5BA-3B3807152A56'.':
FileLoadException - Could not load file or assembly 'Microsoft.Tools.Connectivity, Version=10.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
_
Check VS 2015 Community has Toolkit 1.3 , you my have to uninstall VS2015 and install the version from install page https://developer.microsoft.com/en-us/windows/holographic/install_the_tools
Released 30th March 2016
Should have mentioned I'm running VS 2015 Professional, with Update 2 installed. The page at the link @Jimbohalo10 posted lists Tools(1.2)
"If you choose a custom install, ensure that Tools (1.2) and Windows 10 SDK (10.0.10586) is enabled under Universal Windows App Development Tools node..."
I see no updates listed for VS (checking Tools -> Extensions and Updates), is there a URL where I can update Tools/Toolkit to V1.3 ??
So I don't think the Tools version is the problem. When I go to Settings and try to Modify my VS Pro 2015 installation it is already listing "Tools(1.3)" as installed.
Ran vs_community_ENU setup again to see what has been installed and everything is correct. The only slight difference is that in my original installation I got a message saying "Update 2" and in the new, working, installation "with Updates"
I had this problem as well on a machine that I was trying to run the emulator on. I tried uninstalling and reinstalling VS2015 with Update 2 and uninstalling VS2013, but I was never able to get past the same error.
The only thing that cured my problem was reinstalling Windows 10, which was something I wanted to do anyways because the PC was updated from Windows 8.1. Reinstalling Windows to fix this is not a pretty fix, but it did do the trick in my case.
