Event for cancelled finger ready gesture
Hi all,
I'm using InteractionManager.SourceDetected from the UnityEngine.VR.WSA.Input library to detect when someone puts their finger up.
I can then detect if the user puts their whole hand back down using InteractionManager.SourceLost, or track it with InteractionManager.SourceUpdated.
What I'm really struggling to detect is when they retract their finger while still holding their hand in front of the Lens (basically cancelling the finger ready gesture).
To see an example of what I want to achieve, in the HoloLens shell, hold up your hand and raise your finger. The cursor changes to a disc. Now, retract your finger while still holding up your hand. The cursor reverts back to a dot.
Did you solve this?
@kvnmlr - Are you also trying to solve it?
Yes but at the moment I think there is any alternative to SourceDetected and SourceLost events. (I noticed that the Microsoft Cursor from the main menu is also not working quite right ... it sometimes stays in the ready pose even if your finger is not pointing up.)
But if anyone has an update on this, would be cool to post it here.
InteractionManager has the following events:
Or at least that's what I see with Unity 5.5.0f3 installed.
Isn't Released what you're looking for?
Our Holographic world is here
I have the exact same problem. It seems that SourceReleased is not working. All other events work fine.
I solved it by using the InteractionSourceState.pressed. If it changes from true to false in SourceUpdated(), the Source is Released.
@Barmyard do you feel this is a bug? Maybe a broken implementation? If so, could you open an issue here? Basically just paste in what you said above. That way we can get someone to take a look at it and hopefully fix it.
Excuse me for the late reply.
Yes I think this is a broken implementation. But I think it has to do with Unity and not with the HoloToolkit.
https://docs.unity3d.com/550/Documentation/ScriptReference/VR.WSA.Input.InteractionSourceState.html
InteractionSourceState seems to be a Unity implementation and not a HoloToolkit one.
I am not sure where to file this bug.
@Barmyard I'm asking internally how we recommend raising issues up to Unity. I believe they own the WSA code you mention above but I believe we help them on the implementation. I'll get back on this.
Was this issue raised with Unity?
