IOException: Sharing violation on path - No script - Following Holograms 100 tutorial
Hello, I am new to this, just installed everything according to MS website, including Unity 5.5.0f3 Personal. I searched and read similar error message postings, but did not find a solution.
Following the Holograms 100 tutorial, created a very simple 3D cube. No scripts, nothing fancy, everything according to the tutorial. Here are the Build Settings:
Platform: Windows Store SDK: Universal 10 Target Device: Any device UWP Build Type: D3D Unity C# Projects: Checkbox is checked
Followed tutorial for settings, and the Project Settings-Quality settings.
When clicking Build button, and selecting folder, the only file built is an empty 1KB Visual Studio solution file (.sln), and get the following error in the Unity Console:
IOException: Sharing violation on path Temp\StagingArea\TempSerializationWeaver\UnityEngine.UI.dll System.IO.File.Move (System.String sourceFileName, System.String destFileName) (at /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.IO/File.cs:339) PostProcessWinRT.RunSerializationWeaver () (at C:/buildslave/unity/build/PlatformDependent/WinRT/SharedSources/CSharp/PostProcessWinRT.cs:433) PostProcessWinRT.Process () (at C:/buildslave/unity/build/PlatformDependent/WinRT/SharedSources/CSharp/PostProcessWinRT.cs:124) UnityEditor.WSA.BuildPostprocessor.PostProcess (BuildPostProcessArgs args) (at C:/buildslave/unity/build/PlatformDependent/MetroPlayer/Extensions/Managed/ExtensionModule.cs:155) UnityEditor.PostprocessBuildPlayer.Postprocess (BuildTarget target, System.String installPath, System.String companyName, System.String productName, Int32 width, Int32 height, System.String downloadWebplayerUrl, System.String manualDownloadWebplayerUrl, BuildOptions options, UnityEditor.RuntimeClassRegistry usedClassRegistry, UnityEditor.BuildReporting.BuildReport report) (at C:/buildslave/unity/build/Editor/Mono/BuildPipeline/PostprocessBuildPlayer.cs:186) UnityEditor.HostView:OnGUI()
I tried Unity version 5.4.0f3 to rule out the Unity version (being the latest), with the same error and results. I also verified I have Tools (1.4.1) and Windows 10 SDK (10.0.14393) installed in Visual Studio.
Is there something not covered in the tutorial? Is anyone else getting this error? I don't know what else to look for. Any help would be greatly appreciated.
JinSEA ✭
@james_ashley Thanks for replying. I was creating a new clean folder. I did find the issue. I had 3 SDKs installed. When I removed 2 of them, I got only one error about a missing XAML folder. I uninstalled EVERYTHING, and started over, only selecting bare bones instead of selecting All. It is working now. Thanks!
@JinSea,
Just checking but are you creating a new, clean folder when you do your export from Unity?
@JinSEA,
Cool. Glad you got it figured out.
