Holotoolkit bug? Cursor disappears when Navigation or Manipulation gesture is cancelled
psi
I am using the new HoloToolkit Input Module.
Created an object to respond to navigation gestures.
Added a script to implement the INavigationHandler interface.
Things work well excepting for the fact that the cursor disappears when a navigation is cancelled( hand disappears from view). I am using the cursor prefabs (BasicCursor or CursorWithFeedback) provided by HoloToolkit.
Am I missing something in my implementation?
I get the same effect with the manipulation gestures.
can you post this as an issue directly in the HoloToolkit-Unity GitHub?
