Fixing objects to mapped room
I mapped my room, brought my object into unity, and created 4 walls and a floor just to test how it would come out and the floor is a lot higher than the one in the room i mapped. Also when if i open the app in the same room i mapped and look at a different wall, the test room i designed has completely rotated to that wall. How could i ensure that when my app loads that the room i create in unity stays in the same place? I read about using WordAnchors, but not quite sure how to implement them.
Optionsrandyiform ✭✭
In Github Holotoolkit-Unity project there is an example in this file for placing objects that uses WorldAnchors:
https://github.com/Microsoft/HoloToolkit-Unity/blob/master/Assets/HoloToolkit/SpatialMapping/Scripts/TapToPlace.cs
Then search for WorldAnchorManager usage in this example. This class is defined in utiltiies at https://github.com/Microsoft/HoloToolkit-Unity/blob/master/Assets/HoloToolkit/Utilities/Scripts/WorldAnchorManager.cs5
In Formation, Inc.
