Text to Speech
How can we do text to speech on HoloLens in Unity? I started writing my own bridge using SpeechSynthesizer but I'm a bit stumped when it comes time to play the stream. Looks like the SynthesizeTextToStreamAsync method returns a SpeechSynthesisStream. Normally you would play that with a MediaElement, but since this HoloLens app is a D3D only app I don't have XAML and I don't have MediaElement. Is there another way to play this stream? Or is there a component somewhere in the toolkit that I'm missing to enable this?
Our Holographic world is here
Optionsjbienzms mod
Actually, I really should have come back and updated this. I ended up creating a behavior and it got accepted into the toolkit. It uses Windows speech APIs but integrates with Unity AudioSource so it can be positioned in 3D space and can move along with holograms. The component is called TextToSpeechManager and there is a sample for it under utilities.
I work in Developer Experiences at Microsoft. My posts are based on my own experience and don't represent Microsoft or HoloLens.6
I believe your best bet would be to use XAudio2 to play the audio. You can get started with XAudio at https://msdn.microsoft.com/en-us/library/windows/desktop/ee415762(v=vs.85).aspx.
To verify before you use XAudio2 directly, if this is a Unity app you can use Unity APIs to stream audio that way. Use of XAudio2 should only be required if you're not developing using Unity.
@jbienzms this is awesome! I had to use this today and found your implementation excellent!
Awesome @papiot! I'm so glad it helped.
Hi @jbienzms I found your Scene in the HoloToolkit-Tests, the speech synthesis worked good, but when I asked "What time is it" there was no response, I had opened up the micphone functionality. Can you check what is the reason for that? Thanks!
Hi, have a look at my tutorial on Text to Speech in HoloLens using MR Toolkit latest version. https://codeholo.com/2018/04/12/texttospeech-tutorial-hololens/
Can you please give me the answer on following,
1. Can we change language?
2. What languages are supported?
