Spatial anchors not persisting between hololens restarts?
shekitshekit
edited June 2017 in Questions And Answers
I have spatial anchors working, sort of I guess. They seem to be persisting between app sessions, if I close the app and reopen it they holograms are located in the same spot. However if the hololens shuts down and I restart it, the anchors no longer persist. Is this how it normally works? Is there any way to persist anchors even after the hololens is restarted?
I know this is probably possible because the Holograms app leaves the holograms pinned in the same place even between restarts.
    Are you using the Anchor store? There are several examples in this forum, here is one.
    @MarcDub Yes I am using the anchor store, had come across the link you shared earlier. Still unable to get it to work between hololens restarts. It's completely fine between app restarts.
