Changing colors of objects in Unity dynamically
Hi all!
I'm trying to get my bearings in unity and using scripts to control the holograms and I want to change the colors of different objects (just cubes, but lots of them) every few seconds independent of each other. What would be the best way to go about that to change each object's color? Would I need a new material for each color I am trying to use?
Matt,
You can change the color via a script attached to each cube. The lambert shader in the holotoolkit allows for this, just make sure you have the main color option checked and refer to the unity scripting documentation here:
http://docs.unity3d.com/ScriptReference/Material-color.html
Cheers,
Ryan
Since this is a general Unity question, it is better to ask it in the unity developer forums at: forum.unity3d.com/
