World anchors and space tracking state questions
I'm trying to create a Hololens app, and am currently working on properly implementing world anchors, and their relation with the space they are placed in.
I'm trying to catch the possibility that the Hololens Space finishes loading after the app started, but doesn't match any previous scanned data. I've found that when deleting the only Space we're using in the Hololens settings menu, the World anchor remains, and can't be located anymore, because its data is lost.
Is there a way to get the state and id of the current Hololens space, and an id of the space the World Anchor I'm controlling resides in?
I'm using Unity 5.6 with HoloToolkit for my project, and do my tests on the developer HoloLens.
Thanks in advance.
Great question. The recommended approach here is to store a “canary” anchor for each logic "space" the app cares about (e.g. different rooms or locations), and test its locatability against a SpatialStationaryFrameOfReference (i.e. Unity's world coordinate system) to determine which space the device is currently tracking in (with some allowance for taking time to relocalize). There's nothing currently exposed in the platform to directly reason about which space is being tracked. The only relevant API in the case you described is the RemovedByUser property on the SpatialAnchor which will be set to true when the user has explicitly deleted the Space from the settings page. It looks like Unity may not surface that property directly on their WorldAnchor object, but you can use GetNativeSpatialAnchorPtr to "punch through" to the native platform API and access the property that way if necessary.
1
That definitely solved the space deleting problem, thanks!
