Hololens Emulator is not visible in VS
Microsoft Hololens emulator is installed in my PC successfully as shown in below figure and also Visual Studio is installed with Upadate2
But it is not visible in VS like below figure,
Please help me to solve this issue.
Thanks in advance,
Priya.
@astrani_saipriya ,
You've probably already tried this but:
1) check your control panel | Programs and Features | Turn Features on or off -> and make sure Hyper-V is checked and turned completely on.
2) reboot. rebooting solves HoloLens dev install issues 80% of the time.
Good luck!
Thanks for ur reply james_ashley, I have checked the Hyper-V and also rebooted, but it not works
There are several possibilities:
For testing if it's installed you should go to and test that this exist:
C:\Program Files (x86)\Windows Kits\10\Emulation\HoloLens\10.0.11082.1039\flash.vhd and this
C:\Users\yourUsernam\AppData\Local\Microsoft\XDE\10.0.11082.1039\dd.1268x720.2048.vhd
Some time temp files are making errors in the installation.
If it installed try to uninstall windows hololens emulation image and hololens emulator.
Check that your hyper-v is well configured.
I had the same error twice ( one because I join windows insider and with last release there are some incompatibilities). The first time I have restored my computer to an older time. The second time I have deleted restored all my computer and install everything again with the steps described in this link step by step.
Hope it helps
Just a sanity check, but make sure that the Universal project is selected too.
@astrani_saipriya ,
It looks like you just opened up a Universal Windows app project. This usually works but every so often I have problems with this, too.
Try building a unity application (like the tutorial apps) and deploying as a UWP solution, then running that UWP solution in the emulator.
[P.S. you can also try reinstalling the emulator and see what happens.]
