HoloLens capture recording
Hi, all
I'm developing apps for holoLens with Unity.
My app needs camera. I use the camera in my app.
And I want to take a capture or movie on Hololens.
however, when starting the application, recording is stopped.
Can not it work at the same time?
I'm not sure if I understand your question completely but, if you're saying that your app uses the camera and you want to stream your app to a computer or something then that is not possible as your app already has control of the camera.
However, in my experience you usually can't take a photo or preview the feed but, I have been able to record it at the same time as my app uses the camera and then play it back later once I am done.
AR Developer
