problem windows mixed reality S0002161-101 need fix
i have one month whit my windows mixed reality and i cant use it dont work ,it shows the same error code S0002161-101 need help pleasee
Hi pillopillo,
Have you check this post? It's the same error like yours which might help you. Besides, S* error code typically indicates a problem with a Mixed Reality shell component is preventing Mixed Reality Portal from starting properly.
