Deploying to the hololens
I developed three simple unrelated apps, I deploy App#1 with no issue, when I deploy App#2 it seems to replace App#1, meaning App#1 is no longer on the Hololens. I deploy App#3 and App#2 is gone, is there a setting I’m overlooking.
Thanks
James
Solution Successful!!
Hello Mark, I tried your instructions and the three application are all installed on the Hololens.
Thanks
James1
In Unity go to Player Settings and then open the Publishing settings and change the Package name.
If you are not using Unity then in XCode go to the Package.appxmanifest's Packaging tab and change the package name there.
Each app needs to have a unique package name.
Thanks I will try this today
Thanks
James
