Tagalong canvas changes scale after relocation/movement/re-opening
Hello,
I have a game thingy that resets after it's completed so it can be played again. I start the game with a tutorial sequence in the form of a tagalong canvas with some information, this sequence will be loaded initially.
Upon opening the game the tutorial canvas has the size that I gave it, which is great, but after the game resets and the tutorial canvas opens again for the newly loaded game the size of the canvas varies from extremely small to a little bit smaller to size it should be.
A friend of mine had the same problem and told me it was because the user physically moves during the game and once the game 'restarts' the camera origin (or whatever) is further away.
Basically:
-) Open canvas with tagalong
-) Do your thing and close it
-) Move to paris
-) Reopen the canvas
-) The canvas is weirdly small yet I want it to be the size I defined in the editor
Does anyone know about this issue?
fix: Use the 'SimpleTagAlong' script instead of the normal TagAlong script.
