Vuforia and Image Recognition
GabGab
edited May 2019 in Questions And Answers
Hi! :)
I was following this guide ( https://www.youtube.com/watch?v=u6fT2zaEKVc ) to learn how to create an hologram from an image, i did step by step every thing he does in his video but when i run the project from unity both the image and the 3d object appear in the screen without recognize any image.
I think it's because versions of Unity/MRT/Vuforia are not compatible, but idk how to see if this is the problem.
Tia, Gab.
//---------------- Edit
I'm trying to use Unity 5.6.2f1 with Vuforia 6-2-10 but i can't find the last one, do u know where can i download it?
//--------------- Edit.2
I used Unity 2017.3.0f3 with Vuforia 7.0 and it seems working. The problem now is that: "Assertion failed: Unable to set holographic camera far plane" What should i do? :smile:
//---------------- Edit 3
I've just adjust the clipping planes on the camera and it's seems working, but now i have the same first problem: when i run the project, i see my ImageTarget on the center of the Holo :disappointed:
    //------------- Edit 4 - Last Update
    I'm trying to use last versions both for Vuforia and Unity and the problem now is this:
    "Unable to start ObjectTracker. Your hardware may not support it."
    Do I have to change some settings? I also noticed that on Vuforia Configuartion there is an advise "No camera connected! To run your application using Play Mode, please connect a webcam to your computer".. I don't have any webcam but my Holo are paired, is this another problem?
    TIA Gab
