Intellisense is lacking...
Tony
in Discussion
RaycastHit
What is that? If I hover over the class name in Visual Studio I see nothing. Yeah, ok, I can get that from the Unity docs, but it would be nice if when ya'll (Microsoft) generated the UnityEngine.dll, you pulled in the class and parameters documentation into the UnityEngine library, so that the intellisense would work in VS.
1
You should get Intellisense for Unity classes. Do you check 'Unity C# projects' when you export your project?
Sorry, perhaps I didn't explain that well. I get Intellisense with methods and the parameter names. What I am saying is that there is no explanation describing what the function does and what parameters are/do. Your screenshot is a perfect example, it should say "The barycentric coordinate of the triangle we hit. This lets you interpolate any of the vertex data along the 3 axes." The method descriptions are in the docs, but are not in the DLLs.
I get intellisense for the methods but not the parameters........it's a real pain to figure some of them out, what they're expecting or what they're returning as parameters when you subscribe to an event....
Weird, the intellisense works perfectly for me. It will tell me the available exposed functions and members as well as the arguments.
I do not get, "The barycentric coordinate of the triangle we hit. This lets you interpolate any of the vertex data along the 3 axes.", that Tony is mentioning, but then again most things don't include that in intellisense. It mostly just parses references and files, extracting the functions and their arguments, that's how it's able to intellisense your own code.
Tony you're spot on!
Intellisense in general should look up docstrings - similar to something you'd get out of any decent Python or Lisp IDE. I think the general problem is there are many ways to do docstrings in code. The aforementioned languages have them as part of the spec for defining functions so implementation of this sort of thing is easy.
There may be hope, according to this. If you comment your code with that method (and you're lucky), intellisense may help you out. Admittedly, I haven't tried myself.
You'd think it's a solved problem in this day and age - there is probably a way to achieve this (though, maybe only applicable if you use visual studio, or mono not necessarily both).
