Non-MS developed Titles
Are there any Non-MS Developed / sponsored titles out yet for the hololens? Not 2d apps which just work, apps developed specially for the Hololens?
    Jarrod1937Jarrod1937 ✭✭✭
    There's one in beta by a moderator here. Other than that, I don't think so yet. Since it's only been out in developers hands, and the emulator only helps to an extent, it will be a little bit until there are others I think. My work application is purely internal use only, however, my game I'll release.
    @filharvey yes there are a few trickling out.
    Some free:
    • Galaxy Shield BETA
    • LSrD
      Some pay:
    • HoloMeasure
    • HoloDice
    Expect to see a few more shortly as the Holographic Hackathon participants from various cities start to publish their team projects and devs start to publish betas and works in progress to the store.
    I wonder what is the release lag from finishing the HoloLens app till Microsoft allows it in the Store (like HoloMeasure)
    @Figers Once you submit your app, you should be able to monitor the ETA on dev center while the app goes through certification. I've heard ~48 hours, but the time varies.
