Implement Rotation and Movement in one Recognizer
How can I implement rotation and movement in one recognizer, if I do not like designing two recognizers and transfer between them by voice commands?
Optionsneerajwadhwa mod
@RosieLiu you cannot do that because both gestures are ultimately in the X/Y/Z world space. So the HoloLens does not know whether you want to perform navigation Vs manipulation unless you tell it.
You can register for different GestureSettings and recognize different gestures based on a voice command or some other condition but you will need to toggle them.
This is not a new UX problem - the same is true in 2D. 2D editors have typically done it by providing "handles" for rotation to trigger only rotation of the 2D object. That's a pretty cumbersome UX though for natural manipulation.
For a more natural approach, you can get inspiration from multi-touch screens where a single finger drag/drop does translation while two finger drag/drop can do both 2D translation and 2D rotation at the same time.
Doing similarly in 3D would let you do translation and rotation more naturally: single handed tap and move would translate in 3D, double handed tap and move would translate in 3D, plus rotate in 3D as the hands moved relative to each other. [You could enable concurrent 3D zoom as well].
If you want to see an example of this, check out the "Tower Blocks" app in the Store that uses something like this already - lets you move and rotate blocks to stack them into a tower.
