Create Unity elements from C# for an App, not a Game
I am trying to create an App (not a Game) using Unity elements (ex: Spheres)
From what I have read, a game is continuously refreshed and uses a lot of resources.
I have read that an App will use the messaging queue (if I am not mistaken) instead to refresh only when needed.
My problem is that I cannot find an sample online showing this process.
Is there anyone that could point me to a sample for this ?
Thank you in advance.
Optionsthebanjomatic ✭✭✭
Hey Zorglub,
The "game loop" is sort of a necessity because you need to constantly re-render from new perspectives as the camera (your head) moves around the scene.
That being said, its still a good idea to not do extra work when you don't have to. In Unity, you can reduce the amount of work that happens every frame by not having an "Update" function inside of the scripts you attach to game objects. By default it creates an empty Update function when you create a new script... delete that if you don't need it. An empty Update function still gets called by Unity and has some small overhead.
http://blogs.unity3d.com/2015/12/23/1k-update-calls/
You can than basically use SendMessage or more direct methods of event handling. For example, you can set a game object to respond to the OnSelect message, and then call into your application logic from there.
Hey Zorglub,
That's the kind of answer I was looking for. Thanks a lot for clearing that point.
And the sample
