Character View
Hello everyone,
I have 2 clients connected to a server and each one has a character that can be controlled.
In Unity, a player can see the other player's movement in real-time.
But with the Hololens (emulator), it's quite different: the character is instantiated but not controlled by the hololens like if the emulator has its own character.
My question is how can I make the hololens control this character
Thanks !
How do you control the character from Unity?
Hello @Patrick,
thank you for the reply
I use the First Person Controller script from the Standard Assets given by Unity (more precisely their prefab FPSController)
@shftd,
Are you running the emulator on a separate computer from the one that you're running Unity on? I know we've had networking issues when the emulator client is running on the same machine as another client/server and trying to communicate.
Hello @ahillier,
yes it is running on the same computer. I'm going to test it on separate machines.
I tested with another machine that hosted the server and I have the same problem.
@shftd
I just tested this with Hololens. Hololens worked perfect in rendering the first person view. I used the same FPSController script from Unity's Standard Assets. I have not tried this in the emulator though.
It seems like the emulator is the problem in this case.
