Work account password won't work
Hi Colleagues,
I have an issue with my hololens, i updated my hololens yesterday and now i have to enter my password again. I know for sure that i have the right password for the hololens but i wont work. It gives me the errror code of 0x8007052E. I cant go back to enter another email, so what can i do to let it work properly again.
Optionsahillier mod
Hi @JvanHardeveld,
If you cannot log into your device, then you may need to perform a full device recovery to get back to the starting state. See this doc for instructions:
https://developer.microsoft.com/en-us/windows/holographic/reset_or_recover_your_hololens#perform_a_full_device_recovery5
Hi @JvanHardeveld,
Thank you, i found the solution on the internet it works
What was the solution you found? I've reformatted and reconfigured my device with my MS account info. I set it down on the table, it went to sleep, locked, and now won't accept the password that I just used to set it up.
