How do I display a speaker's text using DictationRecognizer?
TRR
I have a DictationRecognizer object and would like to use the DictationHypothesis event to display the text when the user is speaking. I have it set up and have the method below that takes the text as an argument. How can I use this to display the text on an object or in the camera in Unity?
private void DictationRecognizer_DictationHypothesis(string text) { //Display text }
Optionsahillier mod
A quick way to get text in Unity is to add a TextMesh object (Create > 3D Object > 3D Text) to your scene. You can then set the object's TextMesh.text to display the string that you get from the DictationRecognizer.
@ahillier Thank you for your response - it doesn't look like TextMesh has a text field (I tried TextMesh.text = text; in that method - is that what you meant?)
I think this is the way to do it: GetComponent().text = text; but @ahillier I'm not sure if it's working so can you confirm that this is the way to do it so I know the issue is somewhere else?
Nevermind that is the correct way
