How do I display a speaker's text using DictationRecognizer?
I have a DictationRecognizer object and would like to use the DictationHypothesis event to display the text when the user is speaking. I have it set up and have the method below that takes the text as an argument. How can I use this to display the text on an object or in the camera in Unity?
private void DictationRecognizer_DictationHypothesis(string text)
    //Display text
    @ahillier Thank you for your response - it doesn't look like TextMesh has a text field (I tried TextMesh.text = text; in that method - is that what you meant?)
    TRRTRR
    edited August 2016
    I think this is the way to do it: GetComponent().text = text; but @ahillier I'm not sure if it's working so can you confirm that this is the way to do it so I know the issue is somewhere else?
    Nevermind that is the correct way
